Hi,
Whenever I complete my editing using Ulead 7, I get to the burn disk option, thats fine and I create all my titles etc, but when it sayd 'converting video files' it freezes my PC at 65 - 70% everytime. The other thing to note is that when playing a DVD through my PC, it will freeze the machine anywhere in the film, at different locations everytime. I have XP with a Pentium 4 2.6 GHZ with 512 Ram and a 128Mb Graphics, hardware shouldnt be a problem, it happens when using Windows Media, Power DVD or any U lead application. My Pc never locks up ever, only when video editing or playing any Video file. Is there any hope??
Please help!
Could be a hardware problem. Video conversion makes the computer work hard and components that are not 100% will crap out when they start to heat up. I'd start by swapping the ram, then cpu, power supply and motherboard.
"Art is making something out of nothing and selling it." - Frank Zappa -
Try closeing any crap running in the background, Antivirus, Messengers, .... Do a Ctrl-Alt-Del to get to the Task Manager and see what processes are running and what your CPU usage is.
Try searching Google forums for this problem. It looks like out of memory type error (windows overflows buffer and you are done). XPis good with memory management so my guess would be rather app. Select some (that give you trouble) and try reinstallation. Wrong path in the registry would do the same (same remedy). Clean temp dirs as well.
Hi There and thanks for all your replies, I have removed virtually everything running in the background and when I started rendering I actually got to 94% before she locked up on me. I was so angry
Anyway, I con't see that its a hardware fault, it runs demanding games fine, so why does it lock up when watching a 2Mb Mpeg file using Media Player, surely thats not demanding or enough to heat my processor til its white hot?
I feel a format and fresh install coming on.
Yey.
Computer Locks Up, Freezes Completely After Being On About an Hour
By p_l in forum ComputerReplies: 33Last Post: 28th May 2012, 17:26 -
Computer crashes when rendering video
By David Bruno in forum Newbie / General discussionsReplies: 20Last Post: 2nd Feb 2011, 20:33 -
PC locks up playing WMVs
By slipkid in forum Newbie / General discussionsReplies: 9Last Post: 12th Jun 2010, 12:04 -
Macrium locks computer
By pepegot1 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2009, 12:39 -
Capture Locks on the first
By depsci in forum Newbie / General discussionsReplies: 4Last Post: 2nd May 2008, 15:21
