Does anyone know where I can download the mp4v codec? Or if someone has it, can you send it to me??
Thanks!!
[[GLAY]]
Ah, thank you for your help, but it didn't work. >.< Do you know any where else? Thanks again!!
[[GLAY]] -
O.K., we'll give it another shot. Take a look at this info I copied from Afree:
If you need more help, try the AFree Forum and see if someone can tell you of any other possibility. Beyond this one, I don't know. This isn't an "everyday" codec. Might be something used for streaming video.Ethernet (n): something used to catch the etherbunny
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Which Codec's is Best To Use?
By Artic in forum Video ConversionReplies: 4Last Post: 26th May 2010, 15:39 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
BD Codec?
By kinglerch in forum Blu-ray RippingReplies: 4Last Post: 1st Aug 2008, 21:26
