I've read how to convert AVI to SVCD, but to capture in this format (I have an ATI All in Wonder) requires too much disk space. My best capture seems to be MPEG1 at the BEST setting. Is there a way to convert my MPEG1 file to a compliant SVCD format?
If anyone has ANY ideas, I would appreciate your input.
THANKS, GARY
You could just use TMPGEnc to re-encode the file, but your capture is Mpeg-1. If your player supports XVCD you should consider just doing that.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Thanks, I wasn't aware that TMP would convert MPEG1. The info at this site lists other formats but not MPEG1. Also, I'm new to this, so not sure about XVCD. Is it better than SVCD? What's the difference?
Thanks again for your help. -
Have you tried installing the PICVideo codec
and setting the quality to ~18.
This should allow you to capture 480x480 and
not take up as much disk space.
Then you can encode with say CCElite 2.2.9 which is
really fast and runs on AMD chips as well as Intel.
There several web pages that show how to capture from
an ATI card at standard SVCD resolutions.
supercrew -
supercrew
How do I get this codec. Also what web pages show how to capture at SVCD. This would solve my problem. -
Take a look at XVCD (non-standard VCD) in the What Is section on the menu to the left. It will give you more information then I could in a timely manor.
if you are interested in converting your MPEG-1 to SVCD MPEG-2, i'd load the MPEG-1 into VirtualDub, apply any filters for cleaning up the video, and frameserve it to TMGEnc using the SVCD template. just loading the MPEG-1 into TMPGEnc and re-encoding to SVCD MPEG-2 produces a much worse looking re-encoded MPEG.
How to convert RM/RMVB to AVI or MPEG1/2
By kschang in forum User guidesReplies: 112Last Post: 11th Feb 2012, 20:56 -
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 10:40 -
digital cable = the new svcd format?
By mazinz in forum DVB / IPTVReplies: 38Last Post: 8th Jul 2008, 02:22 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38 -
Trying to convert WMV to MPEG1 on a slow processor
By Gooey in forum Video ConversionReplies: 2Last Post: 21st May 2007, 04:59
