  1. Hi Everyone, first of all thank you for reading this post.
    I have a divx film (717Mb) that i want to burn to DVD via my newly bought DVDRW (Pioneer A06)
    I have read as much as my brain can handle on the guides given here, but when reauthoring the film using TMPGEnc, i just cannot get my head around the settings. I'm not that bothered how long it takes to do as i can just leave this PC sat here doing it.
    But after one or two attempts of creating the files(i opted for Video and Audio) i have selected them to use in DVD X Maker, but im being told a selection of messages form NON Compliant Format, (most commonly) and once i got a setting right that gave me the OK for that, but then it said there was too much filesize.
    I would be most gratful if someone has a real beginners guide to all this, as im very very confused. Ive tried that many different settings, i juct cannot seem to get the hang of it.
    Many thanks in advance.
  2. Member jaxxboss's Avatar
    Apr 2003
    JAX, FL
    Open TMPGEnc and use the wizard. Select dvd and click next, next , next until it asks you where to save the output. Pick a folder, click start. Once done load that file in an authoring program( I use dvd author). Author the file and then burn it. Use a dvdrw. You may also need to change the audio in the divx before you do anything else, but do the above first. A lot of things may need to happen also, like codecs and changing the audio to wav etc... Just try the above first.
