all,
I needs some advice with what specfic brands of media work with the new samsung dvd-rom SDG-605.
Here are my pc and Xbox specs.
DVD Burner- LiteON +- R/RW
Software - Nero 6.0
Media
Fuji DVD+R
Fuji DVD +RW
Maxwell -R
Xbox
EvolutionX V+393 hack
Player Samsun SDG-605b
I have used a few different type of media and the only media that seems to work so far is the Fuji+RW. If does reciginze my back up games when I play them on the +RW. Is there any way i can use either +R or -R media with the samsung player.
So if any of the xbox "power players" out there could give some advice... would be in debt.
Thanks.
the 605's will not read +R media. i think only the 616t pc drive will read +R along with the (old)phillips and thompson.
thanks for the tip ex, is there a specfic type of -R that I should be using. I have tried the Maxwell -R and it could not read the disc.
I have had luck with Fuji & Verbatim -R but had to use Nero for burning as Record Now Dlx would cause the same media not to be read by the drive. YMMV
i use dvd decrypter for all my iso needs. people say use ritek for xbox, somehow when i do, it freezes on certain games, nfl street, doav, etc. used khypermedia & verbatim, both CMC, on those games that froze when i backup with ritek, and they seem to perform better. yet i still stick with ritek, but sometimes go with CMC disc. more convenient if you have a big HD, therefore you could fit dozens & dozens of games and play off the HD
Its been reported that the sammy xbox drive will read dvd+r disk that have been set to dvd-rom with a drive that supports bitsetting. I'm not sure which LiteOn drive you have but if you have one that supports it try it.
Samsung SH-S243D DVD writer - CD media burn quality
By onland in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Feb 2012, 23:52 -
Media Extender - Xbox 360 and HD Content
By BMT in forum Software PlayingReplies: 2Last Post: 8th Dec 2009, 18:01 -
DVD to Windows Media Center Extender on Xbox 360?
By md3699 in forum DVD RippingReplies: 0Last Post: 26th Sep 2009, 20:23 -
Help a noob with some media questions for my Xbox and portable player
By Sulsa in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2008, 15:41 -
Xbox 360 or PS3 as media server??
By Browncoat in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Dec 2008, 01:56
