Hi,
I'm having a devil of a time dubbing with my Panasonic E80 which I consider to be the greatest thing since sliced bread! I'm putting 8 hours of video on the HardDrive in SP from a T-160 Video Tape. I use "Divide Program" and divide the original 8 hours into 8 60 minute programs. I dub 4 hours using 2 DVD-Rs. The machine will not let me dub a third. It marks xs next to the program description and although it starts to dub additional chapters it quits. Finally after doing this a few times the Navigator begins to act erratically. It eventually crashes and defaults to Reformat the Harddrive. I have never used this function but it is the only command that the machine will accept. I reformat and everything works fine. Unfortunately, I lose everything on my HardDrive. The manual describes this as some sort of copy protection as the machine considers the original 8 hours as one program which you are trying to dub several times- my interpretation. I am reluctant to try this again but would like to dub the tapes as I described. Any help would be appreciated.
Thanks,
Peerless
Funny ..... the E80H has a continuous recording limit of 6 hours. How are you even getting 8hrs uninterrupted on the HD?
I'd recommend you break up the source into 2hr. blocks. It's easier to manage and you can create a play list that seamlessly spans multiple 'source' sections up to the 6hr continuous limit...... -
Peerless,
You sent me a private message in regards to this -- my apologies for not getting back to you until now. (Been very, very busy with other stuff!)
At any rate, I can't add any other insight beyond the advice above -- every two hours, or some similar convenient time, hit the "STOP" button and manually break up your recordings. I sure can't tell you anything in regards to why the E80H is acting the way it is -- about all we can do is offer the proverbial "if that doesn't work, try this."
Good luck with it!
thoots
Program to rip chapters to M2TS, other than DVDFab?
By kernunrex in forum Blu-ray RippingReplies: 6Last Post: 1st Sep 2012, 16:38 -
How to auto divide DVD into editable clips?
By yamahaalex37 in forum Video ConversionReplies: 5Last Post: 18th Jan 2011, 01:59 -
how can you divide the screen to two?
By maltesefalconese in forum EditingReplies: 4Last Post: 2nd May 2010, 19:54 -
what program should i use to make some menus with diff chapters?
By shadowofanubis6 in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2010, 00:48 -
Panasonic E80 hard drive crash
By csanders1962 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 25th May 2007, 18:57
