Hello all,
I seem to be experiencing some trouble with my nero, Im running nero 5.5 and never really had a problem with it. The file folders I burn from are those created when I use dvd shrink (VIDEO_TS, AUDIO_TS) when I add the files and click the next button, after I check verifiy data on disk, when I click next to burn it automatically tells me burn process started and almost immediatly tells me burn process failed. Has anyone else had this problem, if so what can I do to fix it.
What is the reason for the faliure? Does it give you a reason? I had something similar once and I used a different DVD+R, and it worked fine. Turned out the media was faulty.
No the media is just fine, best ive used so far but I just dont know whats wrong with it.
Go to the "Tools" section and find a freeware burner that can burn the folders. That might tell you if you need to look elsewhere besides Nero for your problem.
Nero "is" a 4 letter word though you know...
well without knowing what the error is, it's kind of hard to tell you what's wrong.
One thing to check is to see if you have DLA activated. I had to disable to burn with Nero. Used dvdshrink and nero then one day it started to do the same thing. I went nuts trying to figure out why. The only thing I could think of that casued it was that Sonic found an update for itself while burning and activated the DLA on the Disc Drives.
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 12:24 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 20:40 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 14:40
