Hello
I have a dell workstation with dual p4 1.4g xeon processors. My operating system is windows 2000 Professional. Two gigs of memory
I am using Nero 5.5.9.16.
There are no other cd writing programs on the computer. Pinnacle DVD Impression Pro and TMPGEnc DVD author are installed.
On the primary IDE channel, I have two hard drives. On the secondary IDE channel, I have a pioneer dvd 105 and a hard drive. All of the drives are set to cable select, including the dvd 105.
The main HD [c] is set to DMA on, the other hds have the dma off [these are western digital drives]. The DMA is set to on and autorun on for the Pioneer DVD 105.
In entering the control panel, I have no option to set or change the DMA setting.
In burning discs, all complete stating that the burn is successful; however, several discs burn half way through and the recorded surface looks blurry, as if the dye has been smeared--these discs will play with out eror half way through the program. The picture quality is unaffected but the program is only half recorded.
Yet the identical program when reburned will play well and the burned disc surface looks sharp and clear revealing a serious of finely etched grooves.
This problem is random and does not always happen. This happens with all media tried. Currently I am using Ritek GO4 printable discs purchased from the supermedia store.
If there was an error log generated then I might have an idea of where to look.
I must admit ignorance as to issues pertaining to DMA--must all of the drives be set to on?
Thank you
Results 1 to 1 of 1
problem with video disc burning
By rahulcb in forum Newbie / General discussionsReplies: 3Last Post: 6th Mar 2010, 01:49 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
AVCHD burned stops half-way through
By misfitzx138 in forum Authoring (Blu-ray)Replies: 1Last Post: 4th Jan 2009, 18:27 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 14:16 -
NEWBIE - Converted and burned XVID to DVD -- Blurry/boxy on TV
By baldieme in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2008, 18:47
