  1. Am planning on dumping CloneDVD into the trash. Did research and DVD Wizard pro sounds good and also has affordable price. Anyone use this? Is it as good product? If not, what you recommend?
  2. I looked into it a while back and what I think I remember was that it was nothing more than a guide to using the free programs out there. What are you frustrated about with CloneDVD?
    I smell a shameless plug here.
  3. Scam written all over it. Install it if you wish to royally screw up your computer and wipe out important documents.
