Is it possible to create a setup file that conatins ALL the hotfixes and updates and installs them in one shot.
For example, I install a fresh copy of XP and then I click on this setup file and it installs everything automatically, I reboot and my computer is updated. Also can it be possible to add hotfixes/updates to this "setup" as they are released?
Yes
Go here: http://www.theeldergeek.com/slipstream_02.htm
I did it and it should take you about 30 minutes to finish -
Thanks for the info but I do not want to make a slipstreamed CD. I probably didn't explain myself cleary.
For example. I want to make a steup file with ONLY the hotfixes and updates - and be able to update with new hotfixes as they are released - so when I reformat I do not have to sit and download all the update again. I will need to install these on several computers and if I sit and download ALL the updates from the begininning for each one, I go insane.
So after I reformat all I want to do is click on this ONE file and it will install all the updates for me at one shot. -
good question, i was wondering that as well. i want to reformat my hard drive and do a clean install of windows xp, but i dont want to deal with having to download all the updates again. anyone have any suggestions?
http://v4.windowsupdate.microsoft.com/en/default.asp?corporate=true
Download them all, burn to CDR.
The better answer has already been given, slipstream them all into the XP setup disk, then they're already in place during the install.Cheers, Jim
My DVDLab Guides -
Originally Posted by nissmo300
If you read that entire "How-to" it tells you exactly how to do that, specifically Step 6 thru 10. You take the standard XP disk, install SP1 into that disk, download all the patches from Windows update site, hotfixes too. Then your done. I use one disk to install the entire updated SP1 XP on all the computers I build, Takes normal install time, Then when you go to update there will only be a couple new updates. They come out with new ones every week almost.
How can I make SD look like HD?
By Nuke Shower in forum EditingReplies: 4Last Post: 29th Jul 2008, 13:53 -
anyone knows how to make this (example)
By pike8 in forum EditingReplies: 6Last Post: 18th Feb 2008, 16:21 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 06:10 -
Make my PC into a Tivo?
By Xenogear900 in forum DVB / IPTVReplies: 5Last Post: 15th Nov 2007, 13:09 -
I want to make a DVD..
By Nyntendou in forum Authoring (DVD)Replies: 3Last Post: 26th Oct 2007, 11:33
