I have two minutes of video I want to put up online.
I'd like it to be under 3megs and right now the least I can make it is 10megs.
what do you suggest?
Cut the bitrate down by 70%. That should shrink the filesize by about the same amount.
Cheers, Jim
My DVDLab Guides -
At 1.5 Megs a minute, you'll need to use DivX and a small (352x288) frame size.
Compressing 30+ hours of video to 10 minutes?
By nerys in forum EditingReplies: 5Last Post: 8th Jul 2010, 05:49 -
Last few minutes of video frozen...
By JohnC1726 in forum RestorationReplies: 3Last Post: 14th Jan 2010, 08:56 -
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 21:05 -
video file out of sync after 20 minutes
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2009, 04:21 -
Video crashes after a few minutes
By Diego123 in forum Software PlayingReplies: 16Last Post: 4th Jan 2008, 10:04
