  1. Hi i play a VCD on my player Panasonic SC HT 850 and everything it is all right , but when the movie it is about the end it start to stop and jump, some stripes and block appear and the audio it is not clear.
    This happen also for other VCD that i created and burned.
    The source file is a mpeg file downloaded with winmmx.
    The video codec is :MPEG1 (VCD)
    The audio codec is :MPEG-1 Audio layer II
    I encode it with TMPGEnc with the following settings.
    Video
    Stream type : Mpeg1 Video
    Size : 352 x 240
    Aspect ratio : 4:3 625 linee pal
    Frame rate :29,97 fps
    Rate control mode :Constant bitrate CBR
    Bitrate :1150 kbs
    Motion search precision : Normal
    Advanced
    Video source type :Non interlace
    Fiel order :Bottom field first
    Source aspect ratio : 4:3 625 line (PAL 704x576
    Video arrange method : Full screen
    No one filter name selected.
    Gop Structure
    IBBPBBPBBPBBPBBPBB
    Number of I picture in GOP : 1
    Number of P picture in GOP : 5
    Number of B picture in GOP : 1
    Output interval of sequence : 0
    Max number of frames : 0
    Detected Scene change : Checked
    Quantize matrix
    Default
    Audio
    Stream type : MPEG-1 Audio layer II
    Sampling frequency : 44100
    Channel mode : Stereo
    Bitrate : 192
    De-emphasis : flag
    System
    Stream type : MPEG-1 System
    After encoding with this settings i burned the file with nero 6 write speed 4x.
    I think that i have to work on filter settings to solve my problem but i don't know how.
    Can i have any tips ?
    Thank u Federico[/b]
  2. Originally Posted by Federik70
    I don't live in PAL land but will 625 line PAL work at 29.97 fps?
  3. Thank u , i read other message and guides and probably the problem is this.
    for PAL i need 25fps.
    So have i to change this setting Frame rate :25 fps
    Do u have other tips about filter or something else to get the best result from encoding ?
    If i check this MPEG with AVIcodec the information about the video are :
    Video : 526 Mb, 1150 Kbps, 29.970 fps, risol. 352*240 (4:3), MPG1 = MPEG 1 (VCD), Supported
    have i to encode it in pal reducing the frame rate from 29,97 to 25 ?
    Thank u Federico
