I am a total novice at the whole thing but Im sure someone can help me !!
I am having trouble with a dvd player that I have bought for my mother
its a BUSH DVD 2023 (I have read the reports since !!)
The problen is that it wont play any of the cd/rw that I produce off my pc but I dont have a problem with the 2 DVD players in my house a PACIFIC and a CLARITONE
Is there anything I can change on the BUSH or could I do something different when I burn the cds ??
I call then cd/rw but they may not be !! I dont really know
I have downloaded a couple of music mpegs and have written them on to a disc using NERO 5 and then I go to the video cd so can someone tell what exactly I am producing ?? cd/rw ??
If you don't know what media you're using what chance have we got to help?
Have you just burnt them straight to a disk?
Does the folders VIDEO_TS and AUDIO_TS mean anything to you?
Do they play on your PC?
If so, how do you play them, do you just double click the files or do they autostart when you insert the disk?
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Will
Thanks for the reply as I said I am only a novice but hopefully you can help me !!
If you don't know what media you're using what chance have we got to help? How would I find out what media I am using ??
Have you just burnt them straight to a disk? Yes a Datawrite blank disc
Does the folders VIDEO_TS and AUDIO_TS mean anything to you? No !!
Do they play on your PC? Yes
If so, how do you play them, do you just double click the files or do they autostart when you insert the disk? NO I just click on my WINDVD and they play
I hope that helps you and we can sort my problem out
Cheers
Mark
Will
