Hi,
I have converted an AVI to MPEG 2 using TMPGE and setting the values of bitrate to:
2-Pass VBR
Average bitrate 900
Maximum bitrate 2650
Minimum bitrate 350
Enable padding not to be lower than bitrate: disactivated
P = 0
B = 20
The movie has a fps of 23.976and the conversion in PAL.
The movie is 101 minutes long.
The quality that came out is not acceptable, is it because the average bitrate is too low? This is the value I got from the calculator.
In fact, the dimension of the file surprised me because it is 825 Mb and therefore I could burn it on a sincle CD (99 min).
But I prefer to have 2 CDs and the higher quality of SVCD.
Can you help?
Thank you!
Set the bitrate calculator to use 2 cd`s,the bitrate will be around 2000kbps and you`ll get much better picture quality.Also read about the ntsc-pal convert guide in the how to convert to the left for proper conversion.
Johns0,
Thanks for your reply.
Regarding the convertion, once you select PAL as a system, doesn't it convert automatically to 25 fps?
This is what it is shown on the bottom left side of the main scrren of TMPGE once the settings are made, in fact, it is working fine and also when I did add the audio in mp2 format in simple multiplex it was perfectly syncronized.
I read it is not a good idea to convert the file previously, also because the DVD Player does that much better.
Am I missing something??
Thanks -
It does convert to pal but if you dont do the things i suggested then the playback will be jerky.If you find the playback acceptable the way you done then you dont need to bother with the proper procedure.
Vizio VBR-100
By Fraggel in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Oct 2009, 09:29 -
cbr to vbr
By dynamix1 in forum AudioReplies: 1Last Post: 17th Mar 2009, 14:12 -
CBR vs VBR
By prl in forum Newbie / General discussionsReplies: 5Last Post: 11th Jan 2009, 18:48 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55 -
VBR or CBR?
By dizzie in forum ffmpegX general discussionReplies: 1Last Post: 29th Jun 2007, 14:28
