Hi,
I want to put my privat videos ontot a SVCD DVD. Because this viedeos are verry short i have to put arround 50 mpeg files on one DVD. That should be no problem. With a singl mpeg i did it, and it works well.
Now my problem. Some of the mpeg files created with tmpgenc has mistakes. In the log file I get this message:
__________________________________________________ ____________
Starting SVCD2DVD: v1.51.2.0
Begin time: 11:58:55
******** Ripping BIN images to get mpegs (VCDGear )
Analysing File: I:\Test Lea\Lea 20020811 auf Bärendecke vor dem Ofen.mpg
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:01.0d]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'previous_I_offset': [00:01.0d]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:01.1f]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0a.01]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'previous_I_offset': [00:01.1f]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0a.03]
++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
Error getting mpeg details. (probably due to AC-3 audio)
System.Xml.XmlException: There is an invalid character in the given encoding. Line 1, position 47.
at System.Xml.XmlScanner.GetChars(Byte[] srcBuffer, Int32& srcOffset, Int32 srcLen, Char[] destBuffer, Int32 destOffset, Boolean zeroedOut)
at System.Xml.XmlScanner.Read()
at System.Xml.XmlScanner.ScanLiteral()
at System.Xml.XmlTextReader.SetLiteralValues(XmlAttri buteTokenInfo fld)
at System.Xml.XmlTextReader.SetAttributeValues()
at System.Xml.XmlTextReader.ParseElement()
at System.Xml.XmlTextReader.Read()
at System.Xml.XmlValidatingReader.ReadWithCollectText Token()
at System.Xml.XmlValidatingReader.Read()
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at _S_VCD2DVDMPG.210ff09a2516b1a7.b4e369192c57af39(2b c216f3ce925842 a01d771a37e7320b)
-->Processing 1 mpeg files.
############### New MPEG File ###############
Type: VCD
Horizontal Res: 0
Standard: PAL
Audio SampleRate: 0
******** Demultipexing original mpg file
bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
speed increases by, Apachez and Christian Vogelgsang
Saving stream 0xE0 into file I:\Test Lea\Lea 20020811 auf Bärendecke vor dem Ofen_DVD.mpv...
File I:\Test Lea\Lea 20020811 auf Bärendecke vor dem Ofen.mpg is an MPEG-2 Program Stream
Summary:
MPEG Packs = 29641
System headers = 1
Padding Stream packets = 2, total bytes = 3762
MPEG Audio stream 0 packets = 2416, total bytes = 5539888
Video stream 0 packets = 27224, total bytes = 62526421
Saving stream 0xC0 into file I:\Test Lea\Lea 20020811 auf Bärendecke vor dem Ofen-0.mp2...
Summary:
MPEG Packs = 29641
System headers = 1
(Total size: 65MB, Duration: 00:00:11, Rate(MB/Min): 328.36)
******** Resampling audio from 44.1 KHz to 48 KHz
MPEG Audio Decoder 0.15.0 (beta) - Copyright (C) 2000-2003 Robert Leslie et al.
7574 frames decoded (0:03:17.8), -0.8 dB peak amplitude, 0 clipped samples
Shibatch sampling rate converter version 1.29
frequency : 44100 -> 48000
attenuation : 0dB
bits per sample : 16 -> 16
nchannels : 2
length : 34900992 bytes, 197.851 secs
dither type : none
clipping detected : 0.183337dB
(Total size: 5MB, Duration: 00:01:03, Rate(MB/Min): 4.71)
******** Multipexing elementry streams
Encoding Time 17secs.
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File I:\Test Lea\Lea 20020811 auf Bärendecke vor dem Ofen_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File I:\Test Lea\Lea 20020811 auf Bärendecke vor dem Ofen_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (I:\Test Lea\Lea 20020811 auf Bärendecke vor dem Ofen_DVD.mpv)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 480
INFO: [mplex] Frame height : 576
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 25.000 frames/sec
INFO: [mplex] Bit rate : 2519200 bits/sec
INFO: [mplex] Vbv buffer size : 114688 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (I:\Test Lea\Lea 20020811 auf Bärendecke vor dem Ofen_DVD.mpa)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : free
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 2558200
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 13019
++ WARN: [mplex] Discarding incomplete final frame MPEG audio stream c0!
System.Threading.ThreadAbortException: Thread was being aborted.
at Microsoft.Win32.NativeMethods.WaitForSingleObject( HandleRef handle, Int32 timeout)
at System.Diagnostics.Process.WaitForExit(Int32 milliseconds)
at System.Diagnostics.Process.WaitForExit()
at ProcRunner.c5b4b7804027a156.160a0bf4de8f6bd0(Strin g d168ac2ed64c4662, String a6a477a49a1a2599, String 450f47a9028f884b, a0efedb9fec1e88f 8b49c96cd0348808, Boolean 74effd3a0f44569e)
at _S_VCD2DVDMPG.210ff09a2516b1a7.6b5e366e276d88bf(2b c216f3ce925842 a01d771a37e7320b)
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
__________________________________________________ ________________
How can I avoid the error in the Mpeg File....all my files where created in the same session....some are good, some are not good, I have no idea why. I hope somebody can help me with a short answer.
Sorry for my english its not my language
Thank you
Frank
Whilst your mpgs may or maynot be processable the real issue here is that the ä in Lea 20020811 auf Bärendecke vor dem Ofen is causing the problem with the xml parser. Can you rename the file & remove any such characters?
Oh...thanks for the fast repeat...
I am so bad....shure...the german ä...i will check this...
thanks alot again
Greats
Frank
Joining more than 2 mpegs...
By artphotodude in forum ffmpegX general discussionReplies: 2Last Post: 30th Jul 2011, 09:33 -
Ripping DVDs as MPEGs using TMPGenc --- loss in quality?
By DieselsDen in forum DVD RippingReplies: 5Last Post: 21st Sep 2010, 12:09 -
TMPGEnc Xpress 4.0 stuttering conversion errors
By CasanovaFly in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 15:32 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
