Hay guys
I have 10 AVI episodes that are
30 Min in length
100 - 120 MB
Can I reincode them to DVD resolution and fit all ten episodes just over 5 hours onto 1 dvd ?
any infor on fiting episodes on dvd would be great .
I recently bought some burned seinfeld dvds from EBAY that had over 9 hours of video per disk with menus ?
the quality wasnt fantastic but 9 hours is 9 hours right !
Results 1 to 9 of 9
If it were me, I'd encode them with a video bitrate of around 3067kbps, 224kbps for audio and at a 352x480 resolution. They should look decent and fit nicely with those settings.
352x240 @ 1803 VBR & 224kbs audio will give you 5 hours of VHS quality video on one DVD. You could drop the audio to 128kbs & pick up another hundred or so on the video bit rate, but I don't see how you'll ever fit 5 hours of video on a DVD with a 3000+ bit rate.
You are correct! Seems my trusty bitrate calc was set for 2 DVD-R's instead of one. :P I oughta know better.
I seriously have a 9 (4.7 GB) set of seinfeld dvds
180 22 minute episodes that equals 7.3333 hours of video on each dvd ?
how the hell can this be possible ?
and will converting a 100 - 200 meg avi @ 30 mins per episode to mpeg really blow the size out for the 10 files from 2 GB to 10 ?
thanks for the advice -
A single-layer DVD-5 actually can hold over 9 hours of VHS-quality video.
Need to burn TV episodes to DVD
By harishkumar09 in forum Authoring (DVD)Replies: 44Last Post: 3rd Mar 2013, 06:35 -
DVD episodes to MPTS
By waveqam in forum Video ConversionReplies: 3Last Post: 15th Apr 2009, 17:37 -
DVD shrink missing episodes
By CraftCove in forum DVD RippingReplies: 3Last Post: 3rd Dec 2008, 00:53 -
Looking for guide: TV Episodes to DVD!
By munchgrunch in forum Video ConversionReplies: 3Last Post: 16th Jul 2008, 00:19 -
How do you author many episodes to 1 DVD-R?
By 1980sumthin in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2007, 23:49
