Every time i try to merge and cut these two mpegs i get an incompatibility error...im pretty sure that i know the reason for this but i dont know how to fix it...i checked both of the mpegs to see the exact details of their make up and there were a few things i noticed...the scan type of the problem mpeg is zig zag, where as the other mpeg which seems to work fine is alternative...the other difference is that the frame type of the problem mpeg is progressive where as the other mpeg is interlaced.
I guess my question then is if this is the problem how do i go about changing the problem mpeg so that it is compatible with the non problem mpeg and so that they have the same qualities so that i can merge and cut with tmpg enc?
thanks chris
i need to merge them because im trying to make the movie into a dvd...there are two files...both in .mpg format..so they are svcd....and i want to make the two files into one dvd so i can burn it onto a dvd
Its easier to just add the mpgs into the same track without merging,i do that with mpgs all the time,saves on sync problems and the clips plays as one file anyways after.
Tmpgenc dvd author,when you do encode the mpgs make them 352x480 and set the gop to 18 frames maximum.
Are there any software that will SIMPLY cut and merge *.mts without re-enco
By skydutch in forum EditingReplies: 1Last Post: 12th Nov 2011, 04:04 -
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
How can I cut/edit/merge/add some info/add hardsubtitle in one media (DVD)?
By roUndy_sh in forum EditingReplies: 8Last Post: 26th Dec 2010, 17:45 -
Cut and Merge MPEG-2 Files
By flash_49 in forum EditingReplies: 8Last Post: 12th Feb 2010, 10:03 -
How the cut and merge function works on your dvd recorder?
By v1p0n3 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 5th Jan 2010, 05:59
