I loaded a DivX movie into VirtualDUBMP3-Freeze and i scanned for bad frames and it displayed every single frame is bad. Although it plays fine the audio is in-sync and video is fine when i play it in DivX.
The only thing i Did to the file was change the FourCC code from MP43 because VirtualDUB couldn't read it to the DivX FourCC.
Is it just that i knew a better codec suited for the file?
i seriously don't know where i am going... is they a place i can download a shyt load of codecs???
The last thing you want to do to your system is to load a s**tload of codecs. The only cure then would be to format the disk and re-install everything again.Originally Posted by Toby400ex
Only use codecs with caution and bear in mind that some codecs don't work well with certain others installed.
Also, some codecs don't properly uninstall, and ruin the system - unless you are upto fine surgery...
That said, what you need is Microsoft's MPEG4 codec pack. Try the codecs at page
http://www.microsoft.com/windows/windowsmedia/format/codecdownload.aspxThe more I learn, the more I come to realize how little it is I know.
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 18:39 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 04:39 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59
