  1. Guys I cannot find out how to mix a JPEG with an Audio file to use as the background image for DVDs authored by TMPGENC dvd author.
    How do you mix Jpegs with audio to MPEG backgrounds ?
  2. Member jaxxboss's Avatar
    Apr 2003
    JAX, FL
    In TMPGE
    Select ur pic under video and select ur audio in the audio window. pretty simple
  3. Yeah for sure i try that but i keep getting invalid mpeg stream from my Jpeg ?
    What are the setting you use for demuxing or whatever ?
  4. Member jaxxboss's Avatar
    Apr 2003
    JAX, FL
    Ok, in tmpge use the pic in the video window and use u sound u want in the Audio window. just run it and u will have a video with a still pic and the sound. the take that and i go to dvd author and use that as a backgound or whatever. simple. where are you having the problem at?
