Hi making Home dvd's
Capture card to avi files wih pionnacle8
Then tmpgenc+ 2.5 to encode/trim/clip
Back into pinnacle 8 for timelin menus etc
Then intp tmpeg dvd author to finalise into Video_ts files
BUT when i play the dvd I have to keep going into dvd player setup
to change the audio out from pcm to mpeg to pcm
Tried converting wav to ac3 but pinnacle 8 does not recognise/allow me to put it onto timeline
How do i record/change my audio side to pcm compatible dvd playing
p[lease advise
ancient
Since you already have Tmpgenc DVD Author, just get their AC-3 plug-in ($29). It will convert either LPCM or MP2 audio to 2 channel AC-3. The software is licensed from Dolby Labs so it should be OK--I've done a number of DVDs thus far and it works without any problems. Only tihng at the moment, is that it doesn't recode any motion menus into AC3--no big deal to me though. Hope this helps.
wwaag -
Do you have Nero v6.0....? Try to use Nero vision express, it lets AC3 go with 2 channels. Good luck
Used mkvtoolnix and need help making audio from mka to ac3 Major help pleas
By csta in forum AudioReplies: 10Last Post: 2nd Aug 2017, 10:03 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
How to burn avi file with true 5.1 ac3 sound on dvd?
By namesake in forum Video ConversionReplies: 17Last Post: 20th Mar 2009, 10:49 -
Make an xvid/avi from DVD but keep original ac3 surround sound?
By coolchris in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 07:35 -
MPEG-2 With AC3 Sound on DVD
By crazynewfie in forum Newbie / General discussionsReplies: 2Last Post: 16th Sep 2007, 12:53
