I have a load of DTS wav files, converted from ac3 which I originally intended to write to normal CDR and play in a DVD player.
Can I put them on a DVD instead of lots of CDR? I have looked at sonic dvd audio creator, which seems way to complicated for what I want to achieve. I dont want to add any video, just audio files.
No, you need some sort of video. At the very least, a slideshow. Unless you can find a DVD-Audio burning S/W. If you do find it, it'll be expensive.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Thats not true. You can author DVD-A with DVD Lab. You just drop in 24/96 sampled audio track, and bingo, DVD-A.Originally Posted by racer-x
But this is coming in March, you may want to look inot this:
http://www.highfidelityreview.com/n...number=14090740
Jeff -
What are you smoking, hiptune?
I use DVD-Lab and I have made DVD Music compilations with it. You cannot just drop in audio and burn. If you do, it won't work in any player. You have to either put the audio in menus or a slideshow.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Suppose the DVD player expects the audio and video to be in a certain place on the disk? Is that why you have to include some sort of video?
So basically, you can create a section of video for each audio track you wish to include on the DVD, assuming it needs to be the same length as the audio track, and author it with any DVD package, including a menu for track selection? -
Try reading this guide that may be what you are looking for :
https://www.videohelp.com/forum/userguides/193049.php
Hope that helps .......
Easy tool to change audio fps
By davidbowie in forum AudioReplies: 20Last Post: 17th Jul 2014, 05:23 -
I need an easy way to play PC audio over microphone line.
By Nagashi in forum AudioReplies: 3Last Post: 11th Jan 2012, 19:36 -
I need an easy way to replace audio tracks in a DVD
By sanguino2001 in forum Authoring (DVD)Replies: 6Last Post: 2nd Aug 2009, 13:00 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
Easy way to mux new audio track into DVD?
By MrMoody in forum DVD RippingReplies: 2Last Post: 2nd May 2008, 21:28
