  1. A recent Windows update provided a patch for the following issue;
    http://support.microsoft.com/default.aspx?kbid=834489
    basically once you install this update you cant go to a url like;
    http://hordong:woody@somesexsite.com/members
    without getting an 'invalid syntax error'
    the following fix was provided by CJPC @ ps2ownz.com (#ps2ownz on efnet)
    http://jeexlabs.com/fix.zip
    (you dont have to restart after applying the registry fix)
    disclaimer: backup your registry before you do anything. blah blah blah the usual stuff..
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Interesting find, thanks I'll keep it in mind when I install the fix at home.
    I installed the fix but that site doesn't work anyway.
  4. what do you need porn for? you've got tons of beautiful swedish girls around you all the time.. i'm sure you get plenty of tang with the line "y'know, i'm baldrick, the side administrator at dvdrhelp.com"
