I have recorded a movie (files .IFO .BUP .VRO) on a Panasonic DVD-RAM disc 4,7 GB(non-cartridge) with Panasonic DVD video recorder DMR-E50 then I try to copy it on a DVD-RW with Ulead DVD MovieFactory 2 to play it on Samsung DVD player M105 . I can see it but I can’t listen it there’s not the audio why?!
Does Ulead DVD MovieFactory 2 support AC-3 sound ? Panasonic records sound as AC-3.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
nicam:
With Moviefactory 2, you can change the project settings in Moviefactory 2 to Frame size 704x480, compression to variable data rate 8264, and have Do not convert compliant mpeg files checked. It normally skips re-encoding it since the frame size is correct and the average vbr is less than 8264 so it leaves the ac3 stream alone (pass through). Moviefactory 3 doesn't need to pass through the ac3 stream so it is more elegant. Other stuff such as Tmpgenc DVD Author AC3 version and Ulead DVD Workshop 1 ac3/ Dvd Workshop 2 also support ac3 directly.
MOV files won't play audio - RAM problem?
By MJW01 in forum AudioReplies: 1Last Post: 18th Nov 2011, 05:26 -
By MGadAllah in forum Video ConversionReplies: 1Last Post: 28th Jul 2011, 16:43 -
Value ram
By jollyjohn in forum ComputerReplies: 19Last Post: 5th Mar 2011, 06:21 -
RAM!!
By HotDamn! in forum ComputerReplies: 14Last Post: 15th Dec 2009, 07:43 -
more ram?
By Heywould3 in forum ComputerReplies: 7Last Post: 24th Jul 2007, 11:32
