Hye,
I try to play original DVD movie on GSA-4081B recorder and it doesn't work!!! My computer get stuck!! and the only way to get out of this situation is to eject the movie.
I seems to be that some movies working fine and some not!!!
All the movies can be read on a standard DVD (home/computer DVD).
Do you have any sugestions?
Please help.
What can i DO?
(I tried to put DVD geine and to uninstall it, I tried to put the DVD as a master... and it still has the same problem!)
Please Help!!
B.T.W. GSA-4081B burns fine. No problem with that.
Thank you.
Ariel Sh.
Arik etc,
I have the exact same problem, not all DVDs but quite a few. How many others out there have this problem?
What's the solution?
Thanks,
Goobs -
Count me in! I got the same problem!
I can't copy most DVDs. Some can, quite a lot can't. Some DVDs play for a while and then suddenly the entire computer freezes. Can't copy all data out from DVDs I burnt using Nero. Can't copy unprotected data DVDs, also burnt using Nero.
All the situations above end in computer freezing up completely requiring a hard reset.
The burner still burns without a hitch.
I don't think it is the drive but something in the OS. I took my old DVD reader out and plugged in back onto IDE2 in place of Lite-On cdburner, LG still connected. Tried the same things. Results are the same. Got me stumped.
I suspect the drive is over sensitive of bad media or small errors on disc.
Any ideas please share!!Running XPPROSP1, 2.4 P4, 1024ram, 400WPSU.
Hye All!
I Had all the problem you have (And I think I still have it) but,
I did the firmware upgrade from http://tdb.rpc1.org/#GSA4081B
and i think that it makes better.
Rihjt now, after doing the firmware upgrade, I don't have any region (I think it's called RPC1 free).
BYW The upgrade from this site (A101 version) works fine and didn't made any problems to my GSA-4081B.
After I did the upgrade I entered a movie (Original) and tried to open it or copy it and i didn't do anything... again my computer stucked!
So... I ejected the movie and entered it again few time and than it work perfect...
I don't know hot to explain this problem, maybe it's because the Original movie media is soo poor that GSA-4081B can't read it perfectly.
What do you say about this...?
Please let me know.
Thanks.
Ariel Sh. -
How did you apply the firmware upgrade? It says to do it from a pure DOS environment not from a DOS window in XP. How do you do this?
Thanks,
Goobs
PS I seriously think LG has a problem with sensitivity to scratches etc. But I'll see what happens when I apply the firmware, it's really wierd that you eventually got a 'non-readable' disc to work!! -
Gooberoo,
You need to have a bootable floppy with DOS. You have to boot from it and apply the update in the command line. If you run XP you need DOSflopmaker.zip to make a DOS bootable disk. I can't seem to remember where you download the file. I'll email it to ya if you want.
That said. The update has made zero difference. I think all it does is remove region lock so you can play DVDs from any region. -
HI,
I HAVE THE SAME DVD Writter.
GSA-4081B.
JUST EDIT & PLAY.................apnait.com
Problems with DVD LG GSA-4160B
By Jomapil in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Feb 2009, 23:33 -
LG GSA H55N region free?
By Ace-Of-Spades in forum DVD & Blu-ray WritersReplies: 2Last Post: 6th Feb 2009, 08:18 -
lg gsa-4120b dvdwriter
By mustang1967 in forum DVD & Blu-ray WritersReplies: 1Last Post: 29th Jun 2008, 23:50 -
LG GSA-H22N misidentifies RW media
By Overwind in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th Aug 2007, 13:54 -
Cant update my LG GSA-55L firmware?
By kiaconcepts in forum DVD & Blu-ray WritersReplies: 1Last Post: 28th Jul 2007, 07:59
