I run DVD decrypter and all the files have some problem with the TOC! But if i run DVD shrink, This will not happen, Right? Also, Burning with nero really sucks! I recently erased a DVD-RW and the software detects a blank disk but assumes it's a full disk! Nero is a bunch of crap! So would someone help!!!!!!!
I'm also worried about DVD-RWs not working on a PS2. I am currently trying to copy "The Lion King 1½" onto a DV tape without my computer. My computer would skip audio samples and video samples
Listen to this! Nero is the stupidest software in the world! Nero will not allow Burning of DVD source files more than once!
Is there a "FREE" alternative? (Please, no Demos!)
The Nero Log:
Jack Zhang
Timon and Pumbaa Encoding Inc.
XXXX-XXXX-XXXX-XXXX-XXXX-XXXX
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 9/10/1999 4:06:00 AM
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 7:18:06 PM
Nero version: 6.3.0.3 (Nero Express)
Recorder: <HL-DT-ST DVDRAM GSA-4081B>Version: A100 - HA 1 TA 0 - 6.3.0.3
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <SONY DVD-ROM DDU1621 >Version: S1.6 - HA 1 TA 1 - 6.3.0.3
=== Scsi-Device-Map ===
DiskPeripheral : IC35L060AVVA07-0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVDRAM GSA-4081B atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SONY DVD-ROM DDU1621 atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-4081 D: CDRom0
SONY DVD-ROM DDU1621 E: CDRom1
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 8388608 (8388608) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261664kB)
Free physical memory: 76MB (78584kB)
Memory in use : 69 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
8.2.2004
UDF/ISO compilation
2:13:08 PM #1 Phase 112 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation started
2:13:09 PM #2 Phase 114 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation completed (no file modified)
2:13:09 PM #3 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
2:13:09 PM #4 Phase 111 File dlgbrnst.cpp, Line 1800
DVD-Video files sorted
2:13:09 PM #5 Text 0 File Reader.cpp, Line 118
Reader running
2:13:09 PM #6 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
2:13:09 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3882
2:13:09 PM #8 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once, using DVD media
2:13:11 PM #9 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 11276912 (2505:58.62, 22025MB)
Last address to be written: 2071407 (460:18.57, 4045MB)
2:13:11 PM #10 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
2:13:11 PM #11 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: HL-DT-ST DVDRAM GSA-4081B, Media type: DVD-RW
Disc Manufacturer: Prodis - cDVDRW
Disc Application Code: 64, Disc Physical Code: 214
2:13:11 PM #12 Text 0 File DlgWaitCD.cpp, Line 406
>>> Protocol of DlgWaitCD activities: <<<
2:13:11 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2071408 (2071408) = #2071408/460:18.58
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2071408 blocks [HL-DT-ST DVDRAM GSA-4081B]
2:13:11 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [HL-DT-ST DVDRAM GSA-4081B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4242243584, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2071408 | lead-out | 1 | 0x00 | 0x41
2:13:11 PM #15 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
2:13:11 PM #16 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
2:13:11 PM #17 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
2:13:11 PM #18 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 1x (1,380 KB/s)
2:13:11 PM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
2:13:11 PM #20 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 12:52,763 (772763ms) -> OK
2:13:11 PM #21 Text 0 File DVDR.cpp, Line 1512
Recording mode: Sequential Recording Mode
2:13:11 PM #22 Text 0 File Mmc.cpp, Line 19487
Set BUFE: supported -> ON
2:13:11 PM #23 Text 0 File DVDR.cpp, Line 1643
Start write address at LBA 0
DVD high compatibility mode: Yes
2:13:11 PM #24 Text 0 File Cdrdrv.cpp, Line 7941
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-RW (3), Part Version: 2
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 261270 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 02 ................
FE 10 00 02 FF A0 00 00 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
2:13:11 PM #25 SCSI -1122 File Cdrdrv.cpp, Line 1171
SCSI Exec, HA 1, TA 0, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x57
Sense Qual: 0x00
CDB Data: 0x53 0x00 0x00 0x00 0x00 0x00 0x1F 0x9B 0x70 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x10
0x32 0x45 0x03 0x0D 0x57 0x00
2:13:11 PM #26 CDR -1122 File ThreadedTransferInterface.cpp, Line 1573
Unable to recover TOC!
2:13:11 PM #27 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1573
Could not perform start of Disc-at-once
2:13:12 PM #28 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
2:13:12 PM #29 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 1x (1,380 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 9/10/1999 4:06:00 AM
File 'Drivers\PXHELP20.SYS': Ver=2.02.40a, size=16416 bytes, created 7/27/2003 1:32:22 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\ATAPI_CD.SYS': Ver=?.?.?.?, size=30272 bytes, created 6/21/1996 1:09:28 PM (Adapter driver for rec)
File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 8/17/2001 1:51:56 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 1 (Security Option)
THIS IS THE STUPIDEST SOFTWARE IN THE WORLD!!!!!!!!!!!!
DVD Decrypter 3.5.4
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 9th Mar 2010, 14:48 -
Problems Creating ISO with DVD Fab Decrypter
By ViRaL1 in forum DVD RippingReplies: 1Last Post: 25th Jan 2009, 12:30 -
DVD Decrypter from one pc to another
By jwedge in forum ComputerReplies: 3Last Post: 26th Jan 2008, 23:35 -
DVD Decrypter problems - I want the very best DVD ripper
By Lovepeaceguru in forum DVD RippingReplies: 3Last Post: 11th Nov 2007, 19:54 -
Subtitles problems w/ DVD Decrypter and AutoGK
By coyotewrw in forum DVD RippingReplies: 2Last Post: 4th Aug 2007, 14:15
