  1. Is there anyway i can put a mpg that will play right when i insert the svcd on my dvd player. I would like to do this with Nero if it is possible.
  2. VCDEasy will do it. I don't think Nero has that ability, or if it does, it's not obvious to me.
    Cheers, Jim
    My DVDLab Guides
  3. The problem is that when i do a cvd with VCDEasy, it cannot help me doing a menu with few thumbnails of every clip. So it take me 30 minutes to create this menu on a jpeg has about 5 min with the little tools in Nero.
    So i'm looking to do it with Nero or with another software that can do both
    Thanks for your help
  4. Member akbor75's Avatar
    Aug 2002
    Netherlands (Europe)
    i use dvd lab. it's not free but it works great.
    you can put a video before your main menu, which will be played directly after you put the dvd in the player.
    Music was my first love, and it will be my last
  5. Ok thanks. I have a few questions
    Can you create differents menus with dvd lab ?
    Does dvd lab does only dvd or it also does vcd and svcd ?
  6. Member akbor75's Avatar
    Aug 2002
    you can create any kind of menu you want.
    it supports dvd and svcd. i think vcd also, but i don't use that.
    i suggest you check this out: http://dvdlab.net/dvdlab
  7. Ok thanks i will take a look at it !!
