I've autherd a dvd from an m2v and ac3 files using tmpgedvd auther. The problem is that the video is ahead by about 3/4 of a second. Is there any way I can add the difference on to the ac3 file so the movie will be in sync? Thanks.
That worked great thanks. I've got more problems though, the audio sync seems to get progressivly worse as movie plays
i could be having the exact same problem
i uninstalled every codec i could find............... many times
i uninstalled every video player i could find
reinstalled with the most current nimo ffdshow xvid divx
and it still has the same problem
is there any miracle programs called codecs be gone,kill all codecs, codecs killer or could you wipe my codecs
i seriously want to banish every codec on my system
short of a reinstall of my whole system i cant figure out what to do
if any1 could help me i would be deeply aprieciative -
This is not easy to fix. My guess is original file(s) where captured by you or perhaps downloaded Divx/Xvid clips. You are going to have to go back to the source to see what the problem is.Originally Posted by nick90
It all depends on what your source file was to begin with so give us details and perhaps we can help.
as it turns out .......................................
my problem was all atributed to the windows media player 9 update
damn microsoft always tryin to mess things up -
wm 9 update, really?
ive been strugling with this problem for days....!!!!!!!!!
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 6Last Post: 30th Jul 2013, 17:57 -
MKVMerge problem , audio out of sync - says This AC3 track contains 227 byt
By PSPGamer in forum DVD RippingReplies: 2Last Post: 20th Apr 2011, 16:38 -
AC3 Sync problem out of MKV file
By betão in forum Blu-ray RippingReplies: 7Last Post: 9th Jul 2010, 22:30 -
Odd ac3 sync problem
By mayancastle in forum DVD RippingReplies: 7Last Post: 24th Jun 2009, 21:34 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24
