I have had this problem now the last 3 time's i have used Svcd2Dvd.
During the Multipexing elementry streams part Svcd2Dvd just hangs.
On looking at the logs it looks to me like the program cant seem to find the .mpg's it has created to go on to finish the job.
Could you please let me know if i can change any setting's to correct this problem.
Apart from this i have used the program 5 times and found it to exactly
as promised.
Many thanks..)
Here are the error logs if the full logs are need i supply them..
******** Demultipexing original mpg file
(Total size: 794MB, Duration: 00:02:43, Rate(MB/Min): 291.40)
******** Resampling audio from 44.1 KHz to 48 KHz
(Total size: 69MB, Duration: 00:00:41, Rate(MB/Min): 99.65)
******** Multipexing elementry streams
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
**ERROR: [mplex] Unable to open file D:\behind\Battle 01_DVD.mpv for reading.
System.IO.FileNotFoundException: Could not find file "D:\battle&behind\Battle 01_DVD.mpg".
File name: "D:\battle&behind\Battle 01_DVD.mpg"
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.FileInfo.get_Length()
at _S_VCD2DVDMPG.210ff09a2516b1a7.6b5e366e276d88bf(2b c216f3ce925842 a01d771a37e7320b)
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
(Total size: 794MB, Duration: 00:02:21, Rate(MB/Min): 336.60)
(Total size: 73MB, Duration: 00:00:44, Rate(MB/Min): 97.50)
**ERROR: [mplex] Unable to open file D:\Juryntsc&Prozacpal\flix_pzacn.cd1_DVD.mpv for reading.
System.IO.FileNotFoundException: Could not find file "D:\Juryntsc&Prozacpal\flix_pzacn.cd1_DVD.mpg" .
File name: "D:\Juryntsc&Prozacpal\flix_pzacn.cd1_DVD.mpg"
Could you try replaceing the & in the folder name?
I think this may be the issue....SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Hey thanks for the reply ChrissyBoy i just did as you said and it worked perfectly...
Stereo Streams
By Dave1024 in forum AudioReplies: 0Last Post: 21st Aug 2009, 01:54 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 19:44 -
System.IO.FileNotFoundException problem
By bestbuyer_2004 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 24th Jul 2007, 13:49 -
System.IO.FileNotFoundException: Could not find file 'D:\Polar_S2D.mpg'
By RainbowLand in forum SVCD2DVD & VOB2MPGReplies: 18Last Post: 27th Jun 2007, 17:26 -
By captaincaveman in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jun 2007, 13:55
