Hi,
While other people want to split a large DVD titleset on two separate DVD-R's, I would like to do the opposite thing:
I have several already-authored titlesets on my harddisc, and all of them, together, occupy less than 4GB. Naturally, I would like to put them all on a single DVD-R disc; but I do not have the possibility to reedit the original menus.
Can this be done, without altering the original menus? I have in mind a simple, main entry menu, from which I could select which of the titlesets to play.
Cosmin
Do this to each film seperately.
Save all IFOs to a safe place.
Use DVDFab to make a new VIDEO_TS.IFO
If the resulting titleset will play with menu then its compatible to a multiple VTS.
Put the working titlesets together in one folder and make a VIDEO_TS.IFO as above. Can you play all ?
The rest is explained here:
Making a multiple VTS with Ifoedit for a Menu produced with DVD Lab -
You can get the last free Beta of DVDFab here:
http://www.mrbass.org/dvdfab
DVDLAB is available as a 30 day trial - very good.
Is there a guide to merging multiple DVD titles into a single output file?
By Lolipop Jones in forum DVD RippingReplies: 10Last Post: 11th Nov 2016, 19:19 -
Multiple AVIs to a single SD-DVD with MultiAVCHD
By jeffdb27 in forum Authoring (DVD)Replies: 3Last Post: 1st Jun 2012, 15:17 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Multiple Titles In A DVD ISO To A Single AVI
By Simmons in forum Video ConversionReplies: 1Last Post: 9th Aug 2010, 00:32 -
Multiple VCD to single DVD
By Ryan Kelly in forum MacReplies: 7Last Post: 5th Apr 2009, 11:15
