I recently encountered a problem that I haven't before in TMPG DVD Author. I usually rip my files with DVDDecryptor, then load the VOBs into TMPG. For a certain set of VOBs, the audio will not show up, even though when you are selecting audio streams, there is a 2 channel AC3 option avaliable...I thought it might be because I needed that AC3 plugin, but then realized that I had done several other DVDs with AC3 audio...the real question is why isn't the audio showing up? I mean, it IS part of the VOB...
Results 1 to 1 of 1
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 17:46 -
tmpg dvd author - pal ntsc setting?
By jin007 in forum Authoring (DVD)Replies: 4Last Post: 19th Aug 2008, 15:39 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
About the .srt subtle files and the TMPG DVD Author
By ihmcjacky in forum Authoring (DVD)Replies: 2Last Post: 10th Mar 2008, 11:58 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 19:59
