Could I just ask a simple question, and then promise to climb back in my hole.
I need help with cutting out the commercials from the first film I’ve recorded on a Philips DVDR 70. bought a week ago. My hope is that I can do this on the PC when I have swapped the CDROM for a DVDRW.
Where do I start? Thanks.
As I know nothing about the hardware you've used to record I'm going to guess it's captured to mpeg2/DVD format.
You may find some help clicking here.
Good luck and please, stay out of the hole
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
TMPGEnc DVD Author, click add dvd video. Use the built-in cutting tool and reauthor and burn.
Hi Will,
Had a look at the site you suggested. Although it looks good, I am not sure if the Womble mpeg2-vcr application software will do the job or not. My video recorder is a DVD +RW. Would that program edit +RW discs?
Thanks -
You will need to import the files to your computer then cut the video or commercial out the re-author/encode the DVD files and do a new burn to DVD+RW or DVD+R.Originally Posted by smiddy
Trying to record ONLY commercials
By Ch3rryC0ke in forum DVB / IPTVReplies: 7Last Post: 12th Sep 2011, 13:21 -
Hulu plus still has commercials? What a joke
By yoda313 in forum Off topicReplies: 2Last Post: 29th Apr 2011, 19:23 -
Anyone here want to make some spec commercials?
By twells22 in forum Newbie / General discussionsReplies: 2Last Post: 18th Nov 2010, 16:45 -
Editing Commercials
By Jacks_Daddy07 in forum EditingReplies: 2Last Post: 19th Oct 2010, 00:09 -
Copy Protected Commercials
By bjruska in forum Newbie / General discussionsReplies: 4Last Post: 4th Nov 2008, 12:32
