I can get to SVCD compatable format using Pinnacle studio 7 but i cannot then burn CD using Easy CD creator PLatinum edition - any solutions?
EZCD Creator I believe only supports VCD, not SVCD. Check out the Author section on the left, you'll find tuts on how to burn your svcd to cd.
-c -
Yahh, Curtish is right. You can only use Easy cd creator for vcd's.
I recomment that you use Fireburn. It is a great program.
have fun, Henrik
How can I make SD look like HD?
By Nuke Shower in forum EditingReplies: 4Last Post: 29th Jul 2008, 13:53 -
Make SVCD from prepared directory
By Gimballon in forum Authoring (VCD/SVCD)Replies: 2Last Post: 18th Jun 2008, 07:35 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 06:10 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 18:37 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
