  1. I know it is possible to convert WMV video to .AVI (MPEG4 mencoder) with ffmpegX, but then you get no sound. How is it possible to convert both the video and the audio track from the WMV video file into for example a QuickTime format?
    Thomas
    Feb 2003
    Bloomington-Normal
    Can Mplayer for OS X play your files?
    If so, let me know and I will tell you how... Otherwise you might be stuck.
    Jul 2001
    usa
    snapz pro 2, should be able to
    pants on, pants off, pants the floor.
  4. Member Thargok's Avatar
    Nov 2001
    Snapz
  5. Member terryj's Avatar
    N35°25.24068, W097°34.204
    what I do: use ffmpegx to create my video by making an avi.
    Then play the original source WMV and "hijack" the audio
    using Audio Hijack or AHPro, as an AIFF 44.1khz 2 ch stereo.
    Open the AIFF in QT PRO.
    Open the AVI in QT PRO.
    Select the video, copy.
    Select the audio, add scaled the video to the audio.
    save as QT self contained movie.
  6. I had some success using D-Vision 2.
    http://objectifmac.free.fr/Divx4Mac/index.html
  7. D-Vision 2 is using MPEG4 (mencoder) too, just as ffmpegX does. That's why it works with D-Vision 2 too
    Using SnapzPro 2 is not an option for me with my iMac 500MHz G3
    ZeroSix, mplayer for OS X can play my WMV files without a single problem.
    Thomas
