Closed Thread
  1. There are these WM9HD clips i wanna watch on ZoomPlayer, but they dont work because they have WMP copy protection licensing on them. Is there some way to bypass or remove this licensing>
    I wanna use Zoomplayer because it uses less resources, and WMVHD files run smoother than on WM9.
    Please read the forum rules about warez before posting next time
    Mod Offline
  2. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    Not sure how this request will be viewed by the moderators of this site. Your intentions may be honorable and all you want to do is use another tool to exercise your right to view the movie but it could also be argued that you have agreed to these restrictions when you were granted the license. Which means you can only view this movie under certain conditions and for a set number of views. It is very similar to a rental that you only have for a certain period of time and then must return.
    No judgement from me on your request but even if someone had the answer I don't think they would feel free to provide it without some comments from the site reps.
    There's not much to do but then I can't do much anyway.
  3. [DELETED]
    Knowledge belongs to the people.!
