Ive seen alot of posts about dvd backups skipping on standalone dvd players. Alot of replys say its cheap media, but Im not so sure.
My player(Daewoo 5800) used to skip all the time on dvdr. I updated the firmware and have never had any problems since.
Can the firmware make the dvd player read bad media better?
I have about 75 copies that play fine now, never used a blank that cost more than 60 cents on ebay.
I use DvdShrink and nero sometimes, other times I use Dvdxcopy.
My computer is a Gateway P3 450. (Dvdxcopy isnt even supposed to work on less than 500)
So I have a crappy computer, use crappy disks, and various programs, but the problem all came down to firmware on the dvd player. I suggest all with this problem update their firmware before spending more on media or a better computer.
Then again Im a newbie, but its worth a try.
upgrading the firmware on your cd/dvd burner could have made a difference too.. if you're content with using cheap media, then thats up to you.. alot of people dont have the option to upgrade the firmware on their dvd player, so they have to use high quality media.. also, if you let a friend borrow your backup and it doesnt work on their dvd player, they're probably SOL.
Skipping audio problem!
By heffneil in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 21st Mar 2011, 11:02 -
DVD skipping problem. Slow drive speed.
By rayden54 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Jan 2010, 15:37 -
Skipping / Stopping Problem After Burning to DVD format
By shelglen in forum Software PlayingReplies: 4Last Post: 15th May 2008, 09:52 -
Menu Problem - Skipping
By vinnyv07 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th May 2007, 19:17 -
Problem with recorder? Skipping only when recording on DVD
By fastheart in forum Newbie / General discussionsReplies: 3Last Post: 25th May 2007, 10:26
