I am now capturing properly with the correct field order, however, about 2 weeks ago, when I had an old version of MMC, I was getting the backwards field order. Does TMPGEnc alow you to reverse the field order if the video is incorrect? If so, Is TMPGEnc the only program to do this for me? Thanks.
-Brian
I always love LordSmurf's short and to-the-point answers.
Do I just click the checkbox for "Top Field First?" That's the only thing I can think of. Many of those other settings I'm not familiar with.[/img] -
Yes that's it. TOP FIELD. Then save new file.
On a side note, yeah, my answers here are short. Spend most time on my own site's upgrades, e-mail and new paid support forums (which is where I give in-depth answers with pictures and all). Expect big news on the site before this month ends.Want my help? Ask here! (not via PM!)
Here is what I tried.
De-mux in TMPGEnc Plus, and run the video portion through Restream. I then took the resulting video and Re-mux in TMPGEnc. The resulting video was out of sync. I also tried TDA....I loaded the video and audio as seperate sources. I got better results, but still out of sync.
Here's the interesting part. When I go to de-mux in TMPGEnc Plus, I don't have just 2 sreams (audio and video) to save. I have 2 extra streams in my video. One was called a Padding Stream. Is that some mechanism my capture card built into the .mpg file to keep it in sync? My source video is MPEG2, 352x480, 4Mbps.
TMPGEnc recoding always throws my videos out of sync, so I haven't tried that to reverse field order, but I will try tonight. Thoughts and opinions are appreciated. Thanks.
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
Reconciling different Field Order
By vegasarian in forum EditingReplies: 8Last Post: 14th Mar 2009, 12:43 -
VOB2MPG Combines VOB set in incorrect order and skipping the first few min.
By meredithutah in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Oct 2007, 16:03 -
Can DV field order get screwed up during capture?
By miamicanes in forum Capturing and VCRReplies: 0Last Post: 15th Sep 2007, 13:15 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14
