I have just got a pioneer 106 writer, im new to this and would like to know which is the best software and the best media to use i have read previous posts and still not sure, i run windows 98se and hope to back up my dvds prefreably to one disc or would i lose a some of the quality this way?
please advise
Scot R
I'm new here too, but if you look around the forums, it seems like there is no "best media". I don't remember where I read it on here, but sometimes the 'cheapo' discs are actually good media.. for instance I just got a 100 pack of Arita 4x DVD+R's and they are RICOH discs that burn fine at 8x.
I use DVDShrink / Nero to rip / burn my DVD's. Works pretty good for me. Not sure if you have nero or not but I'm sure someone else will let you know of some free dvd burning programs.
Good luck!=) -
there really is no "best" way to copy dvds. you just have to experiment with different programs till you find a setup you like. i use dvd shrink to rip the movies, then nero 6.0.0.23 to burn. windows 98 isnt the best OS to be using for this, mainly because the hard drive is formatted to FAT32 which means the files can not be bigger than 1gb. but it still should work fine for you though. and as for media, i think most of the people on this forum will agree that Ritek/Ridata dvd's are the best. they are also pretty cheap as well. you can pick them up at rima.com, meritline.com, or newegg.com (which i use). i have burned over 300 with no problems
Thanks for replys i have burned my first 2 discs
used dvdshrink and nero both worked fine also used cheepo discs, just have 1 small problem when i tried to play a dvd on my any of my drives lite-on dvd-rom or new 106 writer it was quite poor quality till i reinstalled my graphics drivers now they play fine on the dvd-rom but still poor on the writer why is this i have checked all the settings i can think of DMA ect and it's still the same
any ideas???
Scot R
dvd writer help
By Stephb in forum DVD RippingReplies: 2Last Post: 2nd Feb 2009, 16:38 -
dvd / cd writer
By bill gailer in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jan 2009, 22:18 -
After a new DVD Writer..
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2007, 11:01 -
new dvd writer problems
By carstd01 in forum DVD & Blu-ray WritersReplies: 6Last Post: 25th Nov 2007, 13:58 -
DL DVD Writer?
By LiCal in forum DVD & Blu-ray WritersReplies: 4Last Post: 7th Nov 2007, 01:08
