Winxp, using tmpgenc
I am trying to convert a mpg to vcd compliant mpg
adding filter since the original capture from tv is too light
increasing audio volumn
original has the following spec from avicodec
File : 246 MB (243 MB), duration: 0:15:19, type: MPG, 1 audio stream(s), quality: 78 %
Video : 219 MB, 2000 Kbps, 23.976 fps, 320*240 (4:3), MPG1 = MPEG 1 (VCD), Supported
Audio : 24 MB, 144 Kbps, 16000 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
After conversion the audio / video become out of sync somewhere around the middle.
Have tried the following
demux the original, encode the video seperately, encode the audio seperately, mux them together
any other advice how to approach this?
thanks
The is no freeze on the whole mpg so i guess there is no bad frame.
What program do you suggest to check mpg bad frames accurately?
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Off sync audio problems - is it ripping or encoding?
By kirklt in forum DVD RippingReplies: 3Last Post: 14th Jul 2009, 10:48 -
Audio out of sync half way through encoding
By gertielongbum in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2009, 13:59 -
Higher bitrate encoding causes audio sync issues
By keiron in forum Video ConversionReplies: 3Last Post: 12th Jun 2008, 04:37 -
Encoding yields audio out of sync
By chrisr34000 in forum Video ConversionReplies: 3Last Post: 2nd Jun 2008, 06:21
