I need help i have got a movie file(AVI) and want to put on to dvd. i tried using MainConcept MPEG Encoder and made a mpeg file but when i played it back the timing of them talking and the audio are not in time any help will be good i looked at the tutorials and articles. Any new software would be welcomed. Thanks for your help or for looking8)
if your file is divx or xvid you are probably having problems with vbr audio encoding. open the file in virtual dub. under video select direct stream copy. under audio select uncompressed pcm/wave.. save the new file and use this file to encode to the mpg.
hope this fixes your problem.
good luck and welcome to the forum!
btw the bold print you are using for your post is distracting. i would only use bold print to emphasize a certain point.Donadagohvi (Cherokee for "Until we meet again")
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 13:27 -
swf to gif help plz
By mraza in forum Video ConversionReplies: 2Last Post: 27th Jul 2009, 04:55 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 11:12 -
ADVICE needed plz! As of Feb 08, best format to ripp DVDs? TIA.
By carapalida in forum Newbie / General discussionsReplies: 3Last Post: 13th Feb 2008, 12:11 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
8)
