ive had no problems burning with my toshiba SD-R6012 when until recently neither nero 6 or gear dvd (both mastering and professional versions) can read the DVD-RW i have on the drive. i have used several other media but to no avail
i have tried to reformat my hard drive but still no avail..
would it be possible for me to reset the firmware?
anyone having the same problems as mine?
thanks
I've never had that problem on my 6012, but I don't do a great deal of burning on it, since it's only 1x. I don't see why you wouldn't be able to upgrade / downgrade the firmware to see if that fixes anything. Is this in a laptop? If so, something could possibly be loose. Also, have you tried regular DVD-R discs?
Nothing can stop me now, 'cause I don't care anymore. -
thanks for your kind reply..
yes this is a laptop a FUJITSU C2210 actually.. and yes i have tried regular dvd-r's..
dunno what you meant by "something loose' how could this be when the dvd drive is internal? can you point this out so i can double check?
thanks
Title Writer issues!!!!!!!!!!!!!!
By GermanRedrum in forum EditingReplies: 2Last Post: 9th Mar 2010, 17:31 -
dvd writer help
By Stephb in forum DVD RippingReplies: 2Last Post: 2nd Feb 2009, 16:38 -
dvd / cd writer
By bill gailer in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jan 2009, 22:18 -
After a new DVD Writer..
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2007, 11:01 -
DL DVD Writer?
By LiCal in forum DVD & Blu-ray WritersReplies: 4Last Post: 7th Nov 2007, 01:08
