These coasters are getting expensive. I have yet to make a DVD-R. I have a Que drive, which in Nero reports as a Pioneer DVDR-103. I usually get to around 79% or so and it just fails with SCSI command aborted. I have done the basics - disabled autorun, no background programs (anti-virus, etc.), checked for firmware updates, and loaded aspi32v4.7 (although I read somewhere that I should stick with 4.6, because the 4.7 from adaptecs site is bad). I am not sure what to do next. Anyone throw me a bone !?!
Thanks in advance.
Tim
Here is log -
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Windows 2000 5.0
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 9:20:56 AM
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 7:18:06 PM
Nero version: 6.3.0.3
Recorder: <PIONEER DVD-RW DVR-103> Version: 2.00 - HA 2 TA 0 - 6.3.0.3
Adapter driver: <> HA 2
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <TEAC CD-W224E >Version: L.0E - HA 1 TA 0 - 6.3.0.3
Adapter driver: <atapi> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : IBM-DJSA-220 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TEAC CD-W224E atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
TEAC CD-W224E D: CDRom1
PIONEER DVD-RW DVR-103 E: CDRom0
AutoRun : 0
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523676kB)
Free physical memory: 277MB (284348kB)
Memory in use : 45 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
9.2.2004
ISO compilation
4:05:04 PM #1 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
4:05:04 PM #2 Text 0 File Reader.cpp, Line 118
Reader running
4:05:04 PM #3 Text 0 File Writer.cpp, Line 124
Writer PIONEER DVD-RW DVR-103 running
4:05:05 PM #4 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
4:05:05 PM #5 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once, using DVD media
4:05:05 PM #6 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1563935 (347:32.35, 3054MB)
4:05:05 PM #7 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
4:05:05 PM #8 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: PIONEER DVD-RW DVR-103, Media type: DVD-R
Disc Manufacturer: MXL RG - 01
Disc Application Code: 64, Disc Physical Code: 193
4:05:05 PM #9 Text 0 File DlgWaitCD.cpp, Line 406
>>> Protocol of DlgWaitCD activities: <<<
4:05:05 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 1563936 (1563936) = #1563936/347:32.36
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1563936 blocks [PIONEER DVD-RW DVR-103 ]
4:05:05 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [PIONEER DVD-RW DVR-103 ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3202940928, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
1563936 | lead-out | 1 | 0x00 | 0x41
4:05:05 PM #12 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
4:05:05 PM #13 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
4:05:05 PM #14 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
4:05:05 PM #15 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 1x (1,380 KB/s)
4:05:05 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
4:05:05 PM #17 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 9:49,560 (589560ms) -> OK
4:05:05 PM #18 Text 0 File DVDR.cpp, Line 1512
Recording mode: Sequential Recording Mode
4:05:05 PM #19 Text 0 File Mmc.cpp, Line 19487
Set BUFE: supported -> ON
4:05:05 PM #20 Text 0 File DVDR.cpp, Line 1643
Start write address at LBA 0
DVD high compatibility mode: Yes
4:05:05 PM #21 Text 0 File Cdrdrv.cpp, Line 7941
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
4:05:13 PM #22 Text 0 File Cdrdrv.cpp, Line 1277
16:05:13.254 - PIONEER DVD-RW DVR-103\H2 T0 : Queue again later
4:06:33 PM #23 Text 0 File Cdrdrv.cpp, Line 1277
16:06:33.409 - PIONEER DVD-RW DVR-103\H2 T0 : Queue again later
4:35:44 PM #24 SCSI -500 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x086E0000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x12 0xA8 0xA0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
4:35:44 PM #25 CDR -500 File Writer.cpp, Line 301
4:35:44 PM #26 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
4:35:44 PM #27 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
4:35:45 PM #28 Text 0 File DVDR.cpp, Line 1847
EndDAO: Last written address was 1222815
4:45:50 PM #29 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
4:45:50 PM #30 Text 0 File dlgbrnst.cpp, Line 1658
4:45:50 PM #31 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 1x (1,380 KB/s)
Existing drivers:
File 'Drivers\CDUDF.SYS': Ver=5.3.5.10, size=363927 bytes, created 5/15/2003 2:13:24 PM
File 'Drivers\ADPU160M.SYS': Ver=v3.10a, size=64432 bytes, created 6/19/2003 2:05:04 PM
File 'Drivers\CDR4_2K.SYS': Ver=5.3.5.10, size=58128 bytes, created 5/15/2003 2:13:24 PM
File 'Drivers\CDRALW2K.SYS': Ver=5.3.5.10, size=23436 bytes, created 5/15/2003 2:13:24 PM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 7/17/2002 8:53:02 AM
File 'Drivers\PXHELP20.SYS': Ver=2.02.60a, size=17232 bytes, created 8/27/2003 2:02:00 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.00.2195.6699, size=86672 bytes, created 6/19/2003 2:05:04 PM (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Results 1 to 10 of 10
You might try using rewritable media until you can solve your problem. Also, you might want to edit your post to remove your Nero serial number (if the moderators haven't already done so).
What are you trying to burn on your DVD-R? Are you doing a disc-to-disc copy?
If you're doing a movie backup, you need to rip it and then trasncode it using DVDshrink 3.0 or something like that to reduce the size to fit a DVD-R.
If you say it dies at 3.0gig and you're doing a disc to disc copy of data, try making an image to your hard drive first and burn the image. -
I have a DVD format the Video and Audio directories that I made with TMPGEnc DVD author from a SVCD. So, I am just making a DVD data disc and dragging the two directories into it and even burn at the lower speed (1x). Anything else?!
Hi,
well, i have the same problem too. I am using NEC 1300A. I am having problems burning to DVD-R. I have no problem burning to DVD+RW. I am using a mass storage device (USB). I read in this article http://club.cdfreaks.com/archive/topic/86384.html that the problem might be the USB cable, but i am using the original USB. This is my log on Nero :
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1008), size=48128 bytes, created 12/22/1997 5:23:24 PM
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 7:18:06 PM
Nero version: 6.3.0.2
Recorder: <_NEC DVD_RW ND-1300A> Version: 1.0A - HA 6 TA 0 - 6.3.0.2
Adapter driver: <> HA 6
Drive buffer : 2048kB
CD-ROM: <SONY DVD-ROM DDU1621 >Version: S1.7 - HA 1 TA 0 - 6.3.0.2
DiskPeripheral : WDC WD1200JB-00DUA3 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : SONY DVD-ROM DDU1621 atapi Port 1 ID 0 DMA: Off
CdRomPeripheral : LITE-ON LTR-12101B LS23 ultra Port 2 ID 0 DMA: Off
CdRomPeripheral : Generic STEALTH DVD st3wolf Port 5 ID 0 DMA: Off
SONY DVD-ROM DDU1621 F: CDRom1
LITE-ON LTR-12101B G: CDRom0
Generic STEALTH DVD I: CDRom2
_NEC DVD_RW ND-1300A H: CDRom6
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 456MB (467760kB)
Memory in use : 55 %
Use Inquiry : 1
8.3.2004
ISO compilation
11:40:54 PM #1 Text 0 File Isodoc.cpp, Line 6029
Simulate : TRUE
Write : FALSE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
11:40:54 PM #2 Text 0 File Reader.cpp, Line 118
Reader running
11:40:54 PM #3 Text 0 File Writer.cpp, Line 124
Writer _NEC DVD_RW ND-1300A running
11:40:54 PM #4 ISO9660GEN -11 File geniso.cpp, Line 3882
11:40:54 PM #5 Text 0 File Burncd.cpp, Line 3101
11:40:55 PM #6 Text 0 File DlgWaitCD.cpp, Line 240
Last address to be written: 377887 ( 83:58.37, 738MB)
11:40:55 PM #7 Text 0 File DlgWaitCD.cpp, Line 245
11:40:55 PM #8 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: _NEC DVD_RW ND-1300A, Media type: DVD-R
Disc Manufacturer: CMC MA - G.
11:40:55 PM #9 Text 0 File DlgWaitCD.cpp, Line 406
11:40:55 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 779
original disc pos #0 + 377888 (377888) = #377888/83:58.38
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 377888 blocks [_NEC DVD_RW ND-1300A ]
11:40:55 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [_NEC DVD_RW ND-1300A ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 773914624, ISRC ""
DAO layout:
377888 | lead-out | 1 | 0x00 | 0x41
11:40:55 PM #12 Phase 24 File dlgbrnst.cpp, Line 1800
11:40:55 PM #13 Text 0 File Burncd.cpp, Line 4073
11:40:55 PM #14 Phase 25 File dlgbrnst.cpp, Line 1800
11:40:55 PM #15 Phase 32 File dlgbrnst.cpp, Line 1800
Simulation started at 2x (2,760 KB/s)
11:40:55 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2264
11:40:55 PM #17 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 3:17,335 (197335ms) -> OK
11:40:55 PM #18 Text 0 File DVDR.cpp, Line 1512
11:40:55 PM #19 Text 0 File Mmc.cpp, Line 19451
Set BUFE: JustLink -> ON
11:40:55 PM #20 Text 0 File DVDR.cpp, Line 1643
11:40:55 PM #21 Text 0 File Cdrdrv.cpp, Line 7941
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
End Physical Sector Number of Data Area: 26127F h
Media Specific:
02 FE 10 00 02 FF A0 00 - 00 00 00 00 00 00 00 00 ................
11:40:57 PM #22 Text 0 File Cdrdrv.cpp, Line 1277
23:40:57.359 - _NEC DVD_RW ND-1300A\H6 T0 : Queue again later
11:41:35 PM #23 SCSI -500 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 6, TA 0, LUN 0, buffer 0x030D0000
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
11:41:35 PM #24 CDR -500 File Writer.cpp, Line 301
11:41:35 PM #25 Text 0 File ThreadedTransfer.cpp, Line 229
11:41:35 PM #26 Text 0 File ThreadedTransfer.cpp, Line 223
11:41:35 PM #27 Text 0 File DVDR.cpp, Line 1847
EndDAO: Last written address was -1
11:41:36 PM #28 Text 0 File dlgbrnst.cpp, Line 1658
11:41:36 PM #29 Text 0 File dlgbrnst.cpp, Line 1658
11:41:37 PM #30 Phase 34 File dlgbrnst.cpp, Line 1800
Simulation failed at 2x (2,760 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.57 (1008), size=23936 bytes, created 12/22/1997 6:02:46 PM
File 'WNASPINT.DLL': Ver=V1.18, size=57344 bytes, created 1/26/2004 12:00:00 AM
File 'Drivers\PXHELP20.SYS': Ver=2.02.53a, size=17136 bytes, created 1/28/2004 2:41:42 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 8/29/2002 4:27:50 PM (Adapter driver for src) -
don't be surprised that nero has a bug in it that causes failures on dvd-r's .\myself and a few friends have proven this with different media and writers where as if we use RECORDNOW 6.51 PROBLEMS SEEM TO mysteriously dissappear .hope this helps
Thanks pharlap,
The problem is really gone!! I am using RecordNow 4.5 trial version. i can burn DVD without any problems now :P i guess Nero has bugs and can't really work properly
I'll back that up i had the same problem and even wiped my whole PC but still had the same problem.
I tried record now and worked a minter never had a bad disc touch wood -
Found a link for a demo of RecordNow by Sonic. It's for verison 6.5
http://www.download.com/3000-2646-10066409.html
Is this the same software as Record Now Max ? And if not, which is the prefered software....
TIA
Unable to burn DVD, unable to access the Video_TS.ifo.
By Asymmetry in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2008, 00:02 -
Error when dvd shrink trys to burn thru nero automatically
By themow in forum Video ConversionReplies: 1Last Post: 13th Oct 2007, 14:12 -
nero - dvd burn failure - no seek complete error
By rock in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 15:28 -
Blank Check Command Error In Nero????
By steveuk200 in forum DVD & Blu-ray WritersReplies: 1Last Post: 3rd Jul 2007, 03:31 -
Unable to burn with multiple DVD recorders with Nero 7.9.6.0
By Burner127 in forum Authoring (DVD)Replies: 1Last Post: 7th Jun 2007, 00:47
