is there a correct way of connecting a digicam to pc via firewire. In my manual it says "turning the camcorder on or off while the pc is switched on may cause your pc to malfunction"
What malfunction may this be and what IS the correct way to connect ?
Many thanks.
PC problems ? then visit www.ezpcforum.com
Hmm.. isn't firewire by design a hot-swappable interface. so by specs it would have to allow the turning on and off of devices while connected.
I have 5 devices that I can hookup to my pc via firewire, and I've never had any problems with having to turn any of them off. But if the manual suggests it I would first connect the device, then turn the device on. Couldn't hurt. -
I just made sure my camcorder and PC was "OFF" when I made all the connections, then I turned on the camcorder to VCR mode. I also had my software already loaded and in capture mode. The instant that the camcorder went into VCR mode, my software detected it and ask me if I wanted to use the firewire connection for capture. After that, I've not had a problem. All transfers are at max speed and no dropped frames.
Hope this helps"Technology",...It's what keeps us all moving forward.
AG-DV1000P -- Firewire Connection Crapped Out??
By jbd5010 in forum Capturing and VCRReplies: 6Last Post: 6th Apr 2011, 11:34 -
Firewire Connection - how to secure??
By motown01 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 23rd Nov 2009, 13:39 -
What is the difference in connection of DV and pc between USB and FireWire?
By coody in forum Capturing and VCRReplies: 2Last Post: 11th Dec 2008, 14:17 -
firewire connection without sound
By m baqar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Apr 2008, 08:10 -
Testing Camcorder Firewire Connection
By wacole in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 13th Nov 2007, 10:41
