Hi all could someone tell me want is the best tool for repairing a movie that is out of sync or a good guide that will explain out to repair this
Thread: Out of sync
Out of sync what?
AVI or MPEG capture you created yourself?
Somebody else's aborted FUBAR'd divx trainwreck you downloaded somewhere on the 'net?
What? -
mpeg's from a home movie after transfering to the hard and then putting on to a disc when I played the disc it was out of sync
Maybe the Magic Movie Genie living inside your computer that mysteriously created these files without telling anybody anything about how he did it just doesn't like you?
I think what sacajaweeda was getting at was that we need considerably more info to help analyzing your problem. Try to include info like:
-What was your source? (you said something about an mpeg from a home movie) Was the home movie an analog tape, dv tape, vcd, etc.
-What method was used to transfer to your harddrive?
-What Authoring software did you use?
The more you tell us the more likely you will get a useable answer. -
Best way to fix sync problems is to strip the audio from the file and either stretch or shrink the timeline with a sound editor such as goldwave,this fixs gradual sync problems,to fix constant sync set the delay to plus or minus the time that you estimate that needs to match.
Thanks JohnsO that tried the tool you sugested last night and that has cured the problem thanks again
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 04:08 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 16:17 -
Copying the in sync timing of language1 to out of sync timing of language2
By mago1978 in forum SubtitleReplies: 0Last Post: 19th Jan 2009, 15:05
