If I want to have an "Insert CD 2" screen at the end of my VCD, would I just create a 352x240pixels bmp picture, and then encode to mpg with tmpg using a silent wav? I've never thought about putting one of these screens at the end of the first cd, but I'm thinking it sounds like a good idea.![]()
Anyway, is the way I described above the best way to do this, or is there a better way?
Thanks so much...
No need to add a "silent.wav". Just encode it with no audio, appended to the end of the first CD. Encode another for the end of the movie.
Cheers, Jim
My DVDLab Guides -
Originally Posted by reboot
I appreciate it!
I would use Ulead VideoStudio,Pinnacle Studio,Windows Movie Maker,etc to make a 10 sec. VCD movie,TMPGenc doesn't allow you to set length for stills.Here are some premade stills:
http://members.cox.net/movie_maker/ -
Some people like to have all sorts of screens, start, next CD, end, whatever. It was just a suggestion.
VCDEasy makes it (as it's name suggests) easy to add chapters, menu's, and even a "Next CD Please" screen.
Search the guides for "VCDEasy", by "Sefy". There's a beginners, as well as more advanced tutorials for how to do it.
For myself, I don't care if I see fancy screens, but when authoring (S)VCD's for others, I always fancy them up with menus and such.Cheers, Jim
My DVDLab Guides -
Thanks for all the suggestions!! Very helpful!
I'm looking forward to putting something new and different on my vcd's!! How fun!
Thanks again!
how can i removed crop with winff and make full screen
By phoenixa in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2012, 03:48 -
how can i make full screen to my philips gogear vibe?
By phoenixa in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2012, 11:01 -
A way to auto-make screen caps from videos?
By Scav2003 in forum MacReplies: 15Last Post: 20th Aug 2010, 00:05 -
how to make dvd that does not fill up the screen!
By turbochargedRS in forum Authoring (DVD)Replies: 13Last Post: 20th Jun 2008, 23:37 -
how to make subtitle and insert them into dvd movie
By venziro in forum Newbie / General discussionsReplies: 0Last Post: 30th Nov 2007, 09:53
