Hey, I just made my first dvd out of an anime fansub (starting easy), and the video size is just a little bit too big. Like if they say anything too long, a peice of the first and last word will get cut out on the subtitles. Is there any way to fix this? It's not a huge problem, but obviously I want to make this as good as possible.
Also, for that same reason, are there any good dvd audio guides? the audio's not quite what it could be.
Otherwise, I'm pretty glad my first dvd has worked as well as it has... not even any audio sync problems... yet.
edit* oh, and I used TMPGEnc for the entire thing, Plus for the converting to mpeg, and DVD Author for the setting up/burning of the dvd.
*edit* again... sorry, I did some more searching around and figured it out... also that i even posted this in the wrong forum... my apologies, I had no idea what the source of the problem was. feel free to delete
Results 1 to 1 of 1
MP4 is to big. How can I lower the size?
By DonGallego28 in forum Video ConversionReplies: 6Last Post: 16th May 2013, 03:11 -
Strange video shift when set to big size
By peaceDOThuxDOTde in forum DVD RippingReplies: 1Last Post: 10th Jan 2012, 07:26 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 04:14 -
Size is to big
By g_pentium in forum DVD RippingReplies: 9Last Post: 6th May 2008, 04:36 -
Too big size after join two DVDs
By ByteVV in forum Authoring (DVD)Replies: 8Last Post: 25th Sep 2007, 04:46
