hello i'm looking for a solution for to copy all my dvd's from zone1 in a zone free cause i'm from europe and my dvd player can't playing them , its very difficult to fix it in a zone free
i have tryied the "DVDBACKUP" and it doesn't work, the copy i have made they still in the original zone why????
thanks
Results 1 to 17 of 17
PowerBook Titanium G4 1ghz, PowerMac Quicksilver G4 933 mhz, Imac G4 20 tft 1.25 ghz
this topic has been covered ad nauseum
esseitially dvd backup does not remove the RCE protection
you can 1. use Virtual PC and IFO EDIT to correct this
or 2. try the hades or mac the ripper.
not sure if mac the ripper can corretlly reset RCE but its wroth a try -
MacTheRipper and Hades DO NOT remove RCE at this time. I would give YadeX a try, as they claim to have RCE removal in their latest release.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
If yade doesnt work, IFO Edit is the way to go, but it requires VPC. Its really very easy, open the folder, hit REMOVE RCE and then your set.
Try clicking the link for IFOEdit, and click the 'download' link at the page you're brought to.
and how to do if i don't have virtual pc sofwear????
PowerBook Titanium G4 1ghz, PowerMac Quicksilver G4 933 mhz, Imac G4 20 tft 1.25 ghz -
yadex rip dvd's in zone free????
Yes YadesX rips DVDs zone freeOriginally Posted by harleyman35
And it's also a free application. -
sorry but i tryied yad on some ones and the zone still the same i can't use them on my dvd player its really sux on mac we don't have a solution????
does it play on your mac?
the burned disk
just because it doenst play doesnt mean it isnt region free. Often people are burning them incorrectly or doing a really small thing that is preventing disks from playing.
can you verify the disk will play in your mac using Apple DVD Player and also perhaps on another standalone player?
if not, then take a look and make sure it was burned properly. -
Also, there's a specific way to get YadeX to remove RCE protection. Read the translated instructions I posted in the YadeX thread, and see if that works any better. If you need more help with YadeX, let us know in that other thread.
sorry it still the same i tryied alots of dvd's and still looking for a good softwear to take of the RCE
YADEX,DVD BACKUP, MACTHERIPPER are the same they don't fix this problemePowerBook Titanium G4 1ghz, PowerMac Quicksilver G4 933 mhz, Imac G4 20 tft 1.25 ghz -
DVD Backup should get rid of the code. Maybe you aren't burning it right?
Assemble your crew, I'll meet you outside. -
DVDBackup does not fully remove region coding.
It leaves behind RCE protection which will prevent a NTSC dvd from playing in PAL and vice versa.
YadeX now offeres RCE removal via OSX but you then have to designate a region
perhaps if you did YadeX first, then run that output through dvd2one you would really remove both RCE and Region codes
Free zone Citizen C201 DVD
By Pap in forum DVD & Blu-ray PlayersReplies: 6Last Post: 17th Dec 2008, 01:00 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 14:16 -
Free Zone Alarm Forcefield.
By wtsinnc in forum ComputerReplies: 2Last Post: 11th Aug 2008, 04:14 -
Looking for a region free /zone free DVD Recorder. Questions about the zone
By perdue27 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 10th Mar 2008, 15:09 -
zone free issue?
By glouis in forum DVD & Blu-ray PlayersReplies: 8Last Post: 17th Nov 2007, 07:26
