  1. I can't seem to convert a movie in(divx) to vcd with audio... please help!!! some steps will be good
  2. someone please help...
    Feb 2001
    51`N 5'W #linux & #vcdhelp @ DALnet
    dude, you might as well ask "How long is a peice of string?"
    If you would be more specific in your questions then people will help, otherwise they cant be bothered. Describe all the steps you take and also the software you use - try to be concise. We might be able to help you out more easily if we know more.
  4. I'm using TMPGEnc... I'm trying to rip a copy of shrek... when I try to convert using Tmpgenc it has no audio... and I try encoding it using nero... but the file is way to big... I even tried using avichop.. and can't get it to work... please help
    Feb 2001
    What do you use to rip and encode to avi?
    If you use smartripper and DVD2AVI, then DVD2AVI will produce (...should produce) two files if you have followed the guides on this site to the letter:
    1. A *.d2v file
    2. A *.wav file
    The wav is the audio of the film.
    You then load these into TMPGEnc and encode according to what you want, when it has finished you can cut it to fit onto CDRs. Have you read the guides fully? It sounds as though you are having trouble in the early stages of the process. I would suggest that you read the guide fully and try again, then reply if you still cant get it to work and descibe everything you are doing and the files you produce/use.
