  1. I use nero recode and it loaded the dvd and everything and all of a sudden when I try not it sayd redoce 2 error and something about system cant find the file.What the heck happend? I tried a bunch of difference dvd's to see if it was that one but it said the same thing every time. I restarted the computer but still nothing.
    Apr 2003
    Maryland
    Recode can not copy protected dvd unless you are running anydvd in the background. Are you using that way? It's basically dvdshrink without the ability to decript the dvd. Recode works perfectly for me.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  3. See if this helps:
    Johnny C-Note’s Quick and Easy Guide to Backing up DVD’s Using DVD Decrypter and Nero Recode 2
    http://www.geocities.com/jclind/
  4. First time i didnt use anydvd then it loaded the dvd but hen it wouldnt anymore and I installed anydvd and that does nothing
  5. use dvd43 (free on-the-fly decrypter) works great with recode2, instantcopy, dvd2one, etc. Doesn't work with elby clonedvd though. Win2000 and XP only.
