My Cendyne Pioneer 105 is unable to make duplicate copies of DVD-R's and also unable to make a dvd-r from my camcorder. It always burns successfully but the copy is totally unplayable. (freezes, etc)
Thanks,
Bob
Results 1 to 9 of 9
More info please.
What software are you using? What brand of media are you using? -
One thing I did that has improved my burn speeds and reliability with inexpensive media is the 2X4All firmware update. Unfortunately it's an "at your own risk" update and more than likely there's more to your problem than just the firmware. I reccomend high quality 2x or 4x media as a control to rule out cheap media as the issue if that's what you're using. More info would be a big help as mentioned above.
Nothing can stop me now, 'cause I don't care anymore. -
The media I am using is the CompUSA Brand which I use in my Panny E80 DVD recorder with great results.
The software I use is Pinnacle Studio 8 and Pinnacle Instant DVD Copy and also DVD Xcopy. All with the same poor results.
I have also tried Khypermedia from Office Max with poor results.
My brother has the same DVD Burner as I and has perfect results with same media and software as I!
Thanks -
I had mixed results with KHypermedia and CompUSA discs before I got this update. Since then I've yet to make a coaster, which is a big improvement considering immediately before, I was getting about 2 coasters for every 5 discs. In addition to greater reliability I aslo get much higher rip speeds (up to 12x using the Cendyne / Pioneer) and my 1x discs (Princo/Khypermedia/Compusa[FMI]) all seem to burn at 2x.
Hi,Originally Posted by ViRaL1
Can you tell me where I can get this update and how to install.
Thanks,
Bob -
You can download the zip file for the A05/105 here...
http://pioneerdvd.rpc1.org/#PIONEER_DVR_IDE
Instructions are included in the zip file. Just to be on the safe side (I always do it too), scan the file before you open it. The rest is pretty straightforward.
Good Luck.Nothing can stop me now, 'cause I don't care anymore. -
No problem. Let me know how that works out for you. I don't really know anyone else using it ATM, but I wish I would have found it sooner just thinking about all the time and money I could have saved.
Pioneer 508XD experts needed!
By bjur in forum Media Center PC / MediaCentersReplies: 2Last Post: 22nd Jul 2008, 05:42 -
Pioneer 231s just died, advice needed on new recorder
By heman28 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 7th Feb 2008, 20:58 -
hack needed for Pioneer HTZ-767DV
By xgevsx in forum DVD & Blu-ray PlayersReplies: 1Last Post: 31st Dec 2007, 10:46 -
Illegal Disc Error w/Pioneer DVR-105 in Nero
By Quadzilla in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Aug 2007, 13:23 -
Pioneer DVR-106XA firmware needed
By Stevie69 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Jun 2007, 14:46
