I've converted a number of VCD files to DVD using SVCD2DVD each using its own VTS with the following problems...
1. It plays blocky on PowerDVD XP 4.0
2. It plays with clear with no sound on WMP
3. It plays clearly on BSPlayer but out of Synch!
The MPEGs play fine on PowerDVD before I convert.
I've converted many SVCDs without a hitch.
Does anyone have any ideas? I've tried both VCDGear and VCDXrip options but both produce the same results.
Arrikhan
There is only 1 problem svcd2dvd doesn't convert de video so the blocks should be there already.
So your version of powerdvd is funny cause mine doesn't show blocks after converion. As for the audio sync that is the biggest issue when burning VCD on DVD. You can solve it by reading the sticky about audio/video sync.Greatings,
Yf
Best way to rip blocky or Compressed Dvd movies?
By Bharathnat in forum DVD RippingReplies: 7Last Post: 4th Nov 2011, 11:55 -
DVD at high bit rate - Blocky & grainy on big screen
By nharikrishna in forum Authoring (DVD)Replies: 8Last Post: 27th Oct 2010, 03:46 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 03:22 -
WMV to DVD or VCD Conversion
By MannyNoela in forum Video ConversionReplies: 9Last Post: 6th Feb 2008, 11:22 -
Blocky conversion DV-->Mpeg2 @ 9000Kbps using TMPGEnc 4.0
By kamaleon in forum Video ConversionReplies: 34Last Post: 15th Jul 2007, 18:25
